I’m trying to isolate a rough / inconsistent idle.
My RV-6 has the electric primer system running to a couple of cylinders. I would like to remove the fittings from the manifold and cap the opening to see if I have an air leak in the primer system.
Does anyone know what type of thread / size I would use to plug the openings in the manifold?
Not sure if this is the best plan to take the primer out of the loop to test but it seemed like it to me.
Thanks in advance
Thanks in advance
