There is no benefit with electric trim... manual trim is simple and effective, actually easier to hit and maintain the sweet spot.![]()
I have a speed controller on mine to slow it down and never have any problem hitting the "sweet spot".
Well, I have a good friend flying an RV7 with less than 120 hrs and his electric trim failed just after takeoff. In the fixed position it was in, it made for a creative landing approach. Guess we'll see what part failed.
I'm one of those guys that doesn't bother to trim for landing. Honestly I don't know how folks have have time to normally. I would guess from the time I enter down wind to the point of touch down can't be more than a minute (close in pattern) and I personally prefer to have a little pressure on the stick, gives me a better "feel".
So I guess what I am saying is... why would it make for a "creative" approach with no trim? It's not like it takes both hands on the stick to flare an RV![]()
I have electric and I prefer it but there are times when it can sneak up on you. For example, during a touch and go I keep the plane rolling while the flaps come up, I sometimes forget to trim it to neutral after trimming nose up on final. There is a rude reminder when you give her full power....it almost wants to stall unless you apply generous forward stick. I imagine this would be the same if you forgot to neutralize the manual trim also but if the electric failed in this position...it would be challenging.
