electric fuel pump pressure
wadem
Member
Hi guys, my elec fuel pump died on me the other day and want to buy a facet replacement pump for it. Man was it tough to get at, in the tunnel wedged under all the wiring and both solenoids yeeesh!
At any rate what is the min and max pressure pump i should get? lots of choices on the Vans and Facet site. Engine is a o-320 with a carb not injected.
I hear you should not go above 5.0 psi, if this is true what is the minimum.
Cheers!
Wade
Thanks gasman!
That concours with a Lycoming document I just came across.
-max is 8.0 psi
-min is .5 psi
-desired is 4.0
Wade
My Airflow Performance boost pump relief valve pressure is 25 psi. The roller vane pump is capable of much more.
My IO-540-D4A5 inlet to mechanical fp normal pressure range= -2 to 35 psi. Max= 55 psi.
