The instructions for the electric flaps on the 6A kit are pretty minimal. I started out looking for the length of the flap rods. In trying to figure everything out, I came to the conclusion that there is no way to adjust the flap travel. Flap position, yes, but not travel.
The actuator travels 5" before it runs out of screw threads on each end. The fitting on the end only sets the start position. (Same way with the flap rod length and bearings).
On my plane 40 degrees flap is about the limit before the upper flap skin gets "worry" close to the end of the wing skin. That requires about 3.5" of flap travel.
The reduction in travel distance accomplished by the unequal flap torque rod ends, makes it closer but I think it is still too much.
It appears the excess travel either goes on one end or the other, thereby risking stripping the actuator threads or extending the flaps beyond the limits of safety.
I may be able to make it work once its finally in there but if not, is there any other solution besides designing a limit switch?
Dave A
6A build
![actuator0.jpg](/proxy.php?image=http%3A%2F%2Fpages.suddenlink.net%2Ftismuoi9%2Factuator0.jpg&hash=570977ef2036793da6a4eb648e5dd804)
![actuator.jpg](/proxy.php?image=http%3A%2F%2Fpages.suddenlink.net%2Ftismuoi9%2Factuator.jpg&hash=81ef90e8fa8c2492a7fc584ddf09b483)
![travel.jpg](/proxy.php?image=http%3A%2F%2Fpages.suddenlink.net%2Ftismuoi9%2Ftravel.jpg&hash=0350bead8e88cb6931caa8f9db5123e4)
Dave A
6A build
