Hi, First time post here
Installing the wiring for the elect trim servo in an RV8a, reluctant to drill holes in the elevator spar. Had originally thought that the hole in the spar was for wiring. It's for the manual trim cable and now doubles as servo drive screw clearance (apparently). Any advice? Photos? Also, Id like to see what others have done for routing the wiring for the tail light in the rudder tip. I've looked at several RV's on the ramp and no two are alike, and a couple were questionable.
