I am trying to understand the way to configure the EIS , and I must admitt I find EIS manual quite incomprehensive... Is There an EIS User able to give me a simple way to do....
Great Thanks
These are the settings that I used to set up the IO-540 in my Rocket. They will get you started, but you will need to figure out which numbers and other factors to tweak.
It definitely takes mere mortals like me a fair bit of time to comprehend the EIS settings. The good news is that the EIS is bulletproof once you've got it set up.
I see you have a RV8. What engine? What GRT options are you using, Manifold Pressure, Fuel Flow, Amps? Also what method of fuel quantity are you using? Vans resistance floats, Princeton capacitance probes?
Dominique,
You have a PM with my phone number and personal e-mail.
I'm in France and use the whole GRT avionics suite : EIS + 2 Sports.
Make sure you have the read the following manual
