WingnutWick
Hello,*I have a UBG-16 and an RPM module. I recently converted to toggle switches for the ignition and I am curious how to wire up the module in this instance. I have one of the pickups routed directly to the*electronic ignition RPM output with no isolator and this work fine, except*when the electronic ignition is placed off (during mag check) I lose RPM data. So I would like*to wire up the magneto that I use for the other side but I want to make sure that I am doing it correctly.*
I currently have*the mag P-lead running to a switch which will ground the mag when*closed. I was thinking of simply connecting the other pickup, with an isolator per EI instructions, to that p-lead on the switch. Will this work? Will weird things happen when the switch is closed (grounding the mag)?
I've attached a diagram of the prescribed wiring and what I am thinking.*
Thank you all!
Cheers
Thank you all!
Cheers
