Manchu16
If you are using the stock Vans resistive senders on an EI CGR-30p, would you message me with your fuel configuration (set points) for the two tanks. 9A would be great but any other model would be fine.
I have completed the configuration twice and as you guessed it, both were different enough. I have been having significant discrepancies between the fuel stick and the EI on both runs. The old vans gauges were +/- a gallon at most values.
Just want to see if I can see something glaring in what I did. Tech support has confirmed I am doing the procedure correctly.
Thanks!
Thanks!
