EGT probe hole
Turbowind
Member
While installing my sparkplugs I discovered my EGT probe was touching the sparkplug. Is there a simple fix to repair the old 1/8 inch hole or does it have to be welded ? :eek:
I recently added engine monitor with all 4 EGTs. My original #3 probe was not ideally placed. I simply took a stainless steel flathead screw, cut off the head, leaving about .050" below the head, placed it in the hole and put a stainless steel clamp over it.
Don't know who's probe you have but many can be bent to allow clearance. Give the manufacturer a call and see if it's OK to just bend the probe to get clearance to the plug.
The hose clamp and screw repair that Mel mentions is a common fix,m I have seen used successfully many times.
Good Luck,
Mahlon
"The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
