loopfuzz
I'm wondering if anyone has done experiments seeing if you can use one brands K-type probe with a different brands EGT monitor (that expects a K-type probe of course). I didn't see any postings on this.
The problem I could see is that each probe might give off a slightly different voltage depending on temperature of the heat it's exposed to. That and they may be response differently at different temperatures then what the monitor/gauge is expecting. (though if they are both k-type probes it seems like they would be close.. right?)
If someone was to compare a couple of these, they might find out that you could use a Falcon K-type probe (a bit of cost savings) on a GEM egt monitor.. Which is the case for me...
Chris.
Chris.
