EGT Fluctuation
Kupde
Active Member
Patron
Just changed out the fuel restrictions on cyl#3 and #4 on my RV-10 from an 0.028 to a 0.027. Test flight shows a very brief EGT drop(3 to 5 seconds) while going through the leaning operation on cylinder #3 only. Cylinder #3 drops about 200 degrees below the others(1200F vs 1400F) for the 3 to 5 seconds and then recovers with no further fluctuations. This repeats anytime going back through a leaning operation at different altitudes and engine settings. Never seen this before- anyone have any thoughts?
Kevin
RV-10
Very interested in the replies you get on this. I'll be balancing my injectors soon as I progress through phase 1.
My EGT on one cyl scrolled quickly downward and back up again shortly before the Dynon-supplied probe in question went T.U. for good, and had to be replaced at about 5 hours TT.
Sounds like #3 is running too lean. Can you upload the data to Savvy and share a link?
Kevin
RV-10
I would be very suspicious of that EGT probe/wiring. I had a similar pre-failure signature on one of my ALCOR EGT probes very early on (~50 hours).
Swap the probe, see if the signature follows the probe -- if so, replace the probe.
Usually, issues with fuel injectors resolve themselves VERY quickly -- like a stumble that the EIS doesn't even see, or they don't resolve at all -- total blockage.
+1
Sounds more like an indication problem than a fuel delivery problem. Pretty hard to have a fuel issue that can cause an EGT to drop then regain 200* in 3 seconds.
Larry
https://apps.savvyaviation.com/flights/4730142/86ffcb46-1bde-45ff-a053-b3c28bb00ca0
Not sure if you can get to the data with the link above? Also, no change in CHT and I'll do as suggested with the EGT probe.
Kevin
RV-10
Thanks for the link. Definitely a probe connection issue, as mentioned above. GAMI spread is pretty good with #2 trending leaner.
Time: 00:14:28-00:14:54
EGT2 peaked at 12.2
EGT3 peaked at 12
EGT1 peaked at 11.8
EGT4 peaked at 11.8
EGT5 peaked at 11.8
EGT6 peaked at 11.8
GAMI spread is 0.4
I love data...
You can definitely see something going on there --
EGT on #3 drops out frequently, 9:08, 16:20, 19:29, and so on, regardless of fuel flow settings.
Another oddity...
Keep an eye on the #2 CHT.
Note 11:41 to 14:32 and 21:08 to 26:41 -- #2 CHT is NOT following the normal distribution or rate of change.
This tells me the #2 Cylinder is burning too hot / too fast as the fuel flow increases (richer:faster, leaner:slower), change to a smaller orifice (e.g. .027" from .028") and see if that curve flattens out.
Thought I would thank folks who had commented on this one. I found the smoking gun which was small chafe in the insulation between the 2 thermocouple wires. The red wire wore through where it was rubbing against the opposing wire nut. I guess best practice would be to insulate all the T/c connections before attaching the final sleeve. I’ve tried to attach a picture but not sure how well the attachment will come through.
Kevin
I would place the lock washer under the nut. It looks like the washer is under the screw head...
A star washer should be fitted between the ring terminals as a first course of action as per instructions for this type of connection.
