sbateman7799
Member
I just added a PAR200B Audio Panel (and the remote TRIG radio as Com1) to an older RV-12.
I made the various harnesses using the PAR200B diagrams and almost everything is working...except...I'm not hearing the various "voices" and tones from the Skyview Classic.
The stall sound is working.
Worked with the old set up (Garmin SL40 and Flightcom 403), so I suspect that I missed an audio input to the PAR200.
Looking at the wiring diagram, the various tones get mixed inside the AV-50000A control module.
I assumed that everything got mixed together and routed to the Intercom connector (in the AV-50000A) as "Mono Mixer Out, on pin 24...
So, two questions:
1. On what signals do the EFIS sounds get sent to the Intercom connector? Perhaps Stereo Mixer L/R Out?
2. What else, as well as the stall horn, get mixed onto Mono Mixer Out?
Thanks for any insight.
Steve.
So, two questions:
Steve.
