Can someone tell me if say the Skyview or GRT EFIS can monitor/track 2 VORs and only have 1 SL30. I know the SL30 has the ability for standby on the COMM but was not sure if this would work on the nav too. Hope this makes sense.
Usually mine is set up to show the NAVSRC as the GPS and the two bearing pointers to show Nav1 and Nav1 standby. NAVSRC is what the autopilot will use if engaged in that mode. To show the Nav1 standby pointer you will need to activate monitor on the SL30. All this is easier done than said. Easy answer is what Brantel said--yes.
