Suggestion
Scott, install looks very nice. I will plan something similar. Couple of thoughts-if you flip the filter clamp to the inboard mounting hole of the unit, might be easier to reach the bolt when it's time to change the filter. Also, if you move it to the inboard, the line from the filter to the pump could be flipped to the outside and under the filter. That would move the line farther away from your left foot. You may have already tried it and may not work for something I'm not seeing. Looks good--I'm going to copy it!
Steve
Skyking902001
RV-8 in progress
