So I re-checked all the wiring and settings that has to do with my echo. Moved the plane outside and the 327 transponder shows pressure altitude at the field elevation. The fields in echo app are not populated except for the aircraft id(hex code) and N number. My foreflight app says ownship not detected. So this means the adsb out is not transmitting.Right? Would this change when I fly the airplane? I have flashing green lights fron the echo. 2 long and then 2 short
