Easy electric trim retrofit
Tony Spicer
Those with manual elevator trim know how sensitive it is at anything above pattern speeds. Mine was no exception. Easy solution to install electric trim was to just leave the green snake in place and install the trim servo in place of the manual lever. No room on top of the stick grip for the DPDT trim switch, so I put it here.
Tony
No need for an indicator. Just look at the arm. If there's about 1/2" showing, it's close to neutral. Or feel it with a finger.
Tony
