I just installed my upgrade doublers onto the bulkhead under the stab.
I did not think it was necessary to remove all the top skin rivets as in Van's instructions and it wasn't. It can all be done from inside the fuselage.
Drill out the two top rivets on each side of the angle as shown in the instructions
Since the doublers are CNC punched, you can use the opposite side part as a drilling template on the FRONT of the bulkhead. Cleco the doubler using the two holes you just drilled out.
Space out the doubler at the bottom with a piece of 1/8 scrap to clear lightening hole depression so it is parallel to the bulkhead, match drill and cleco as you go.
Remove doublers, deburr them and the bulkhead.
Place the correct doubler on each side on the aft side of the bulkhead.
Rivet as per instructions.
Took me 45 minutes total
