Earthx ETX900 venting - What did you do?
moespeeds
Friend
For those running vented ETX900s mounted inside the fuselage, how did you run the vent lines overboard?
I ran a pair of static-port vents down through the belly, and enlarged the internal holes with a drill bit. My battery is mounted behind the baggage compartment wall.
See the vent hoses joining a Y, then down through the fuselage floor.
Parts came from an EarthX kit.
Check with them if it's still available?
