EarthX battery
Frodo63
I'm New Here
Has anyone modified their battery harness to accommodate the earthx? The top metal plate that keeps the battery secure Is making contact with the battery pole.
I swapped over to the box that EarthX supplies. It secures the battery from the center front. No risk of shorting out against a wrench.
I also changed to the aluminum battery box that EarthX sells. Further modified it to use #8-32 screws & platenuts and a slightly longer top "clamping" plate. I didn't care for the sheet metal screws directly into the aluminum.
