jmk
Member
Earlier in the wing construction I drilled the outboard rib tooling hole (aft) for insertion of a plastic grommet. Now that I'm starting to install the aileron I have found that this hole was to be used to aid in the alignment of the ailerons. I've tried to use the center of the drilled and undrilled holes but with the pushrod adjusted to the length called out on the drawing that measurement appears to be too short. Any suggestions?
jmk
jmk
