I have the same port for both.So what are y’all’s thoughts on using the same port for the E-mags and the EFIS MAP or should I run different cylinders to supply the MAP?
RV-6 O-320 160 hp with dual E-Mags and GRT glass and remote engine sensors
Weve been doing it for years, literally 100s of planes world wide.I take the MAP off of Cylinder #3, then tee'd off to the map sensor and both P-mags. Working fine for the last 10 years/1100+ hours. Be sure to have some sort of snubber/orifice in the line to dampen the pulses.
EXACTLY how I have mine set up. Has worked perfectly for over 700hrs.I take the MAP off of Cylinder #3, then tee'd off to the map sensor and both P-mags. Working fine for the last 10 years/1100+ hours. Be sure to have some sort of snubber/orifice in the line to dampen the pulses.
I used the #3 cylinder port to provide MP sense for my GRT glass panel (MP sensor box aft of firewall), and for vacuum advance on my SureFly EI - through the Showplanes billet sensor mount with built in restrictor. I think I bought the Showplanes sensor mount from FlyBoys. I also have one of those for my fuel pressure sensor.So what are y’all’s thoughts on using the same port for the E-mags and the EFIS MAP or should I run different cylinders to supply the MAP?
