When you wire the canopy switch don't forget to load the canopy switch file. It is a very small file. This enables the vocal warning above the RPM you choose. I set mine for 1900 RPM. On start and during taxi the canopy widget will show the canopy not locked but no vocal warning. I chose 1900 so I could do the run up with the canopy in the venting position. If RPM exceeds 1900 (in my case) a vocal "Check Canopy" comes through the audio. You can edit the file to change the RPM setting.
