New RV-12 owner here. I'd like to explore and practice using the Skyview while NOT flying nor running the engine. Concern: Running down the Odyssey battery.
Van's response: Should be okay for 15-20 minutes.
Dynon's response: Suggest hooking up to charger.
Odyssey's response: Don't use a charger; use a DC power supply with an adjustable voltage regulator - 0-10 amps, 14.4-14.8 voltage. OR - more simple: have a secondary battery you can hook up in parallel, or use instead of Odyssey battery.
Disclaimer: I am in over my head and don't want to make expensive mistake. Having posted a thread about charging Odyssey in this forum, the consensus was that Odyssey batteries like to be left alone; definitely don't use a trickle charger, and a significant number of responses advised not using any charger - complex or otherwise. However, Odyssey sells a charger specifically designed for maintenance.
Have any of you come up with an inexpensive and non-complicated procedure that would allow me to simply sit in the plane, turn the master switch on, and "play" with the Skyview for 15-20 minutes without jeopardizing the start-up of the engine and avionics at a later time?
Thanks in advance. Jim
