Mark,
Have you turned it completely off and back on? If it's stuck on the backup battery you can push buttons 1,2,5 at the same time to force a shutdown.
If it happens after a power cycle, the only thing I know of that could cause that is a hardware failure inside the unit. It means the main processor can't talk to one of the accessory processors.
--Ian Jordan
