Hello,
I have just over 100 hours on my quick panel built by Advanced Flight Systems. The panel is composed of 2x 10" Dynon HDX screens with all systems connected to the Advanced ACM.
It had worked excellent until recently, so I thought I would see if anyone else is experiencing the same minor issues before I dive into taking connectors apart.
1) After the last software update, my Strobe/Nav toggle switch doesn't work correctly. Initially, Selecting Strobe would turn on both the strobe and nav lights and selecting Nav would turn on only the nav lights. This was nice as I could turn off the strobe lights while performing night-time run-ups and still remain visible. Now, selecting Strobe activates the strobe lights and selecting Nav turns on the Nav and Strobe lights. This could be a wiring issue on my end, but the timing was odd as it occurred immediately after upgrading to firmware version 15.3.3.
2) After upgrading the software several updates ago, the defrost switch is now inop and the defrost fans stay on any time the master switch is on. Previously, the defrost switch controlled the defrost fans correctly.
Has anyone else run into these minor issues?
Thanks in advance for your help!
![vfr-rv7-skyview.png](/proxy.php?image=http%3A%2F%2Fwww.dynonavionics.com%2Fimages%2Fproducts%2Fafs%2Fvfr-rv7-skyview.png&hash=5963dc9e0b4ad6ebe7c59e1e4639a4ea)
