Dynon Skyview Engine Monitor Layouts
MidwestMan
Active Member
I have the basic 4 cylinder carburated lycoming sensor package from dynon and 2 SV-Classic D-1000 displays. The engine monitor layout editor is clunky, and I'm not enjoying sitting out in the hot sun trying to adjust settings. I would think dynon would have a layout ready to go that you could just download for a 4 cylinder lycoming, but I can't find anything. Does anyone know if such a thing exists and where I might find it?
Thanks!
I think provided you have set the EMS wiring connections up as described in the installation manual for a four cylinder Lycoming you should be able to select engine type in EMS setup and the screen should be populated with all the appropriate settings and icons.
