Dynon Servo Issue
Moura
I am having some issue with my servo (SV42) on pitch axis on my RV10. It slips way too much. Today I ran a servo test on the ground and the servo was not able to move the elevator up, not even on the ground. I believe it is faulty and the controls are very light on ground. What should I do.
I and running latest software (3.0)
Moura
What is your pitch axis torque limit set to?
What hole did you use on the servo arm to connect the servo pushrod to the pitch controls?
Some have stated that the RV10 needs the SV52 servo. Talk to Dynon about this and if you both agree, they most likely will swap you out.
Dynon is working on a different servo for the RV-10. It's supposed to be available mid May. We have the SV-52 and it has not cured the problem. Give Dynon a call and ask for Nic.
Ron
