The Dynon pitot heat contoller has a single white wire that can go to a light in the panel to indicate status or it can go to a Skyview display. I did not find specific instructions in the Dynon manual for hooking this up to Skyview but it appears that the Skyview is pre-configured for EMS pin #9 to handle this function. I am assuming that I should connect the single white wire from the pitot heat contoller to EMS pin #9 and I will be done. Is it really that simple? Thank you.
