Smilin' Jack
If any one here is running a dynon SV261 with the Dynon ADS-B have you ever checked with center or approach control to verify that they are receiving the block containing your N Number.
I am running dual Dynon's with the above transponder and during my transponder check with the local avionics shop they do not show the Mode S in limits under the sensitivity and thus my mode S is not being transmitted. This is the second xponder from Dynon. Center is receiving the mode C altitude read out just fine but they do not show the block that should be displayed with the N number.
I have full ADS function
The n number show up on the test unit but because the sensitivity is out of the db range it is not transmitting it?
Dynon is working with me on this... But they use a out source avionics shop for their repairs.
Any ideas?
Smilin' Jack
Any ideas?
Smilin' Jack
