Happy New Year! Dynon has switched our source of engine pressure sensors to solid-state Kavlico sensors. Kavlico is a US company that has been making high quality sensors for over 50 years, and is well known in the aviation industry.
We are selling these solid-state sensors individually, and they are now included standard in our engine sensor kits. We have also optimized the sensor ranges to better match engine pressure ranges for greater resolution and accuracy. (The older sensors and kits are still available if needed.)
Our new pressure sensors are priced at $85, which is (as usual) a significant discount over the price that anyone else sells them for.
These new solid-state sensors require different wiring from the older VDO sensors, with a third wire needed for 5-volt power.
The new Kavlico Pressure Sensors:
NOTES:
* All sensors are threaded 1/8-27 NPT.
* All sensors may be used for any liquid.
* The following description shows the most common usage.
PART # ..........PRICE......... DESCRIPTION
101715-000 ......$85................. 5 PSI Gravity Fed Fuel
101690-000 .....$85................ 15 PSI Carbureted Fuel
101716-000 ......$85................ 50 PSI Fuel Injected Fuel
101693-000 .....$85................ 150 PSI Oil
-Robert
Dynon Marketing
NOTES:
-Robert
Dynon Marketing
