wirejock
I'm using down time to draw schematics and hit a road block.
Here's the design.
AP servos and ADAHRS will route to a network hub somewhere in the aft area. Power (red), ground (black) and AP disconnect (yellow) will be broken out before the hub per Dynon.
The ADAHRS connects all wires to the hub according to Dynon.
The hub cable runs forward to the EFIS. Probably to another hub connecting the panels.
Question...
Is there any reason the yellow from the hub aft/forward can't be used as a path for it's intended purpose (AP disconnect) if if is broken out on both ends?
Does the ADAHRS use it for some other purpose?
No reason to add a wire if a usefull one is already there and it's the right color!
Question 2
How about the red and black? They may be too small for AP servo power though. Does the ADAHRS use red and black?
Here's the design.
Question...
Question 2
