dynonsupport said:We added a lot more to the software as well, such as winds aloft when you have a GPS, )
frankh said:So if thing works and "prevents" reverse sensing then I guess if I had GS (only available if you have an SL30 which I don't) then it makes the 1600 dollar nav head/GS slope meter pretty redundant?
frankh said:the EFIS calculates your TAS from the ASI reading and altitude?
mgomez said:As far as I can tell, the only thing you can do through the nav head that you can't do through the EFIS is set the OBS. The new firmware rev requires that you tweak the OBS through the SL-30.
Nope...it won't work with the 430 at all. The 430 does not have serial output of the GPS data like the SL-30. This is why the SL-30 is almost always supported first on new EFIS designs -- it's a heck of a lot easier. For now the Dynon appears to only support the SL-30.frankh said:With the GNS 430...So presumably the hSI will be stuck at "North" the whole time?
Jamie said:...and OAT.
Jamie said:Nope...it won't work with the 430 at all. The 430 does not have serial output of the GPS data like the SL-30. This is why the SL-30 is almost always supported first on new EFIS designs -- it's a heck of a lot easier. For now the Dynon appears to only support the SL-30.
Clarification: you can most likely have the Dynon display GPS course data from the 430, but not NAV data.
dynonsupport said:We added a lot more to the software as well, such as winds aloft when you have a GPS, better AoA alarms, MPG and range on the EMS, flap and trim indicators, and shock cooling alarms.
Here's our update page:
http://dynonavionics.com/docs/support_software_200610.html
Feel free to head over to our forums and tell us what to do next![]()
dynonsupport said:The GNS430 will not output anything from the NAV radio via serial. If you can get an HSI from the NAV on your GRT unit, you're using ARINC-429 or an analog connection the radio, not serial. The 3X+ the price gets you these interfaces.
True - my error. Since the internal table is only correcting TAS using IAS and the other factors. I forgot it was a unidirectional calculation. Thanks.dynonsupport said:FYI, the GRT system doesn't cal IAS, since that would mess up correlation with other things in the plane. It only cals TAS, but that's what matters for winds, and would be the same thing we would do if needed.
Yep...I wish Dynon would add RPM and MP on the HSI screen and/or on the EFIS screen. It seems silly not to make it an option. There must a some technical reason for not doing it.Paul Eastham said:Very cool...my EFIS/EMS combo now does a lot more than it did when I bought it. Thanks to the pop-up EMS alerts and cross-device displays, I plan to keep the HSI up on the bottom screen en-route.
dynonsupport said:There's no technical reason that we don't show MAP and TACH on the EFIS, it just didn't make it into this release. It is high on our wish list for future software updates.
We are going to need to figure out where to stuff it on the screen though.
Are you not using the split screen option? I know it's not the same as just displaying a few parameters on the HSI screen.Jamie said:Yep...I wish Dynon would add RPM and MP on the HSI screen and/or on the EFIS screen. It seems silly not to make it an option. There must a some technical reason for not doing it.
the_other_dougreeves said:Are you not using the split screen option? I know it's not the same as just displaying a few parameters on the HSI screen.
Why not just make it an "info item" on the EFIS (where you can normally put OAT, G-meter, bus voltage, etc). That seems like a logical place.dynonsupport said:There's no technical reason that we don't show MAP and TACH on the EFIS...We are going to need to figure out where to stuff it on the screen though.
RV7Guy said:Is this a download or another piece of hardware? I have a 10A and downloaded the DG a while back.
