Tbone
Trying to figure out the audio out from my D180 & D100 - HS34 interface... Each dynon has audio out functions. My HS34 should connect to my audio panel from pin 25 (naturally thru a variable resistor). Does the D180 & D100 communicate to the HS34 thru the DSAB for this function? Should the audio out (HS34) pin 25 connect to the aux audio input (pin 23 J1) on the audio panel? I plan on using all audio output functions on both Dynon units (if possible or probable). Am I on the right track?![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
