Lynnb
I"m trying to connect the EarthX remote sensor wire to the Dynon EMS. I ran a wire from pin 10 to the back and as soon as I connect it, the red fault light on the battery comes on, disconnect the light goes out. Is this because I haven't configured pin 10 (Brown/Yellow) yet in the set-up, or is there something else I need to do? I read one user installed an in-line diode, is this needed?
Looks like this might be normal though, found this in the earthX installation docs:
Configure the input as “active low”, “alarm” type. Note; when Dynon power is off the LED inside battery
may be dimly lit (less than 120uA, too small to drain the battery).
