Toobuilder
Replaced one EGT probe today and all is good when hanging in free air (reads ambient- matches the other 5). Bending wire all along length and at probe and connection points shows stable, correct readings. Insertion into pipe and loose fitting of clamp also shows all good. However, as soon as the clamp is snugged up, EGT goes to 850 ish.
Sounds like a bad probe with a return to Spruce, but just wanted to check with the group for any similar experience before I do that.
