blueflyer
Just put in a Val Nav 2000 tied into my Dynon D100 and it works!!!
At first I tried to connect the Val via pin 3 on the D9 connector on the D100. No joy. Then I tried to tie the Val Nav into the line that connects pin22 on the D100 D25 connector to the D9 connector. No joy. Then I tried to connect the Vals R232 ground and then again connect the Val line to the line between the two Dsubs on the D100. No joy.
Finally removed the existing pin in the pin 22 slot on the D100 and put in pin 5 (serial transmit) from the Val. Connected power and ground on the Val and PRESTO!! It works as advertised with the D100!!
