On my D100, I followed the guidance to adjust the HP setting so that the unit reads PK (just the simple LOP-PK-ROP indicator) when I am at Peak EGT. I have a 160 HP engine and I had to drop the HP setting to around 150. I don't know if that means my VE and or power output is lower or higher than a typical 160 HP engine.
My question is whether or not having the lower HP setting effects the % power data provided on my display. It seems that my %age's have been showing a bit higher than what I remember similar settings being in the past, but I have also done a top overhaul.
Can someone help me understand this functionality and the configuration a littler bit better.
Larry
Larry
