jthocker
I have been having a hard time getting my Dynon D180 compass to calibrate.
In the Dynon manual, to calibrate the compass module, you start with the airplane on a compass rose aligned with north. You then hit a button, wait 15 seconds while it gathers data, then turn to east, then south, then west, waiting 15 seconds each time for it to collect data. At the end of the process, while still aligned with west it completes and you're done. The compass should read 270 right! Well mine never would. It would read 255,
105, 175, and 015 for the cardinal points. It hasn't been much of an issue because I fly it VFR and I'm just a wingman so I usually just follow somebody anyway, but with no projects little squawks now can be addressed.
The airplane's twin, with a nearly identical install performs fine.
Dynon went so far as to send me a new compass module to try, no luck though!
Here's a pic of my compass installation. It is the SafeAir kit, installed in the right wing.
![](/proxy.php?image=http%3A%2F%2Fimg106.imageshack.us%2Fimg106%2F3768%2Fsafeairinstall.th.jpg&hash=48497d49c537d31d7442e8c38c043933)
I have a strobe cable, an 18 ga. wire for Nav. lights and a 14 ga. wire for the landing lights running out to the wing tip all running thru the heyco snap bushings. Paralleling this wire run and about 2 inches away is another shielded cable for the compass module. I sent this pic to Dynon and Mike thought it looked good to him, but asked me to run a compass of some sort near the module to see if it would deflect. I verified to him that all the hardware was stainless, and that I didn't think the compass was necessary but I would try it.
Guess what, taking a standard spare Cessna compass and starting with it 2 feet above the module, and gradually lowering it to the module, it deflected about 20 to 25 degrees.
A beer at Oshkosh to the first person who can identify the smoking gun!
