Paul 5r4
I have the D 100 and the D 120. I've wired up per dynon's instructions with the variable resistor from radio shack. My problem is this. I have BARELY any tone in my headset when I press the audio test buttons on either dynon instrument. If the engine was running I wouldn't hear them at all. I've tried both pilot and co-pilot sides, played with any and all volumes etc. I've double checked the ground as well as the rest of the wiring and all looks ok.
I did find a post from Stein from 2009 that said dynon "audio out" alarms don't play well with the flightcom intercom. That's what I have. Is this still the case? His advice back then was to cut the wire and forget about having an audible alarm. I was sure hoping to have this feature. Any help is appreciated!
