I just put two servos and an AP74 in our RV-6 and am wondering if there are some "standard" settings for the dozen or so options in 5.4 that work well for a -6. I posted in the 6/6A forum but got only crickets...
I'm also hearing some noise in the headset/intercom when the servos are energized - sounds digital. I read that a ferrite noose might do the trick. I know Vans puts a 2200uf cap to ground on the roll servo possibly to deal with this kind of thing.
Thanks for any input!
UPDATE: Flew it yesterday! The roll servo is working great with both HDG and NAV but pitch is quite sensitive and it over and under shoots altitudes. I plan to reduce sensitivity first and then play with gain and the VSI settings - I wish I knew what these do and in what order they should be modified. Searches over on the Dynon Forum are not yielding too much specific info.
Neil
KDVO
Neil
KDVO
