BJohnson
I am beginning the installation of the Dynon Autopilot Servo installation and have run into an issue. The aluminum tube between the bellcrank and the servo arm is at an angle that the tube contacts the bellcrank without being close to the servo arm. See the attached photo
Do i need to change the length of the spacers, or shim out the rod end bearing with washers? Changing the spacers will place the bellcrank offcenter from the pushrod passthrough hole in the bulkhead.
I emailed dynonsupport but it being the holiday and all, thought that there others online that might have resolved this already.
