Dynon AOA Retrofit?
Rolly9
Active Member
Has anyone removed the Van's Al pitot tube and installed the Dynon AOA? How did you handle the hole where the AN fittings came through?
Thx. Rolly
RV-9
AOA Retro
I had the same problem. Here's what I did:
(from memory--forgive the lack of AN numbers.)
First, I 'plugged' the hole with one standard washer (diameter just fits), then on the inside, I used a large 'bearing' washer. On the outside, I used a Tinnerman counterunk washer.
Then I bolted everything together with a flathead screw and nut.
This plugs the hole and gives a nice finished exterior appearance.
If this is not clear, I could take some photos, but I think if you play with it, you'll see what I mean.
Vern Little
RV-9A (baffles)
