Has anyone with a Dynon D100/D120/HS34 setup tested the AoA audio alarm under firmware V5.0, this worked fine under 4.2 but in 5.0 I cannot get the audio to sound until after the stall has actually occurred. Tried all the settings and sound actuating positions (bottom of yellow, bottom of red etc), and tried tone vs voice etc. Visual chevrons are working fine suggesting the calibration etc is OK.
Dynon is looking at the backups but no answer yet so I thought I would check with the flying side as it may be a simple user setup issue that I changed somehow after the update.
