Dynon 17.1 Release RV-12 with Aithre O2 Sensor
HEB1022
Member
I see that Dynon has released the new 17.1 version, which looks like it has alot of goodies. I am looking forward to trying it. While looking at the new sensor file, it seems as if Dynon is now including the Aithre in the baseline sensor file. While that might be good news, I recommend a side-by-side verification with your existing sensor file, before loading it. Vans, if you are monitoring this thread, it might be good to take a look also. My concern is that when I was researching the sensor file in the past, the Aithre used in the RV-12is SLSA uses what is called "standard" pin out. An option exists to use "enhanced pin", but that takes a different sensor file. Aithre publishes both separately. It looks to me that Dynon is including the enhanced settings (not standard) in the new 17.1 sensor file. If anyone has more information or tested the new sensor file with RV-12is, can you publish your findings below?
Thanks in advance,
Harry Burnette
