I used my Dynavibe the first time and it is amazingly simple to operate, but the optimization process is a little tedious it appears that the best solution will usually end up with weight added BETWEEN two adjacent holes in the starter flywheel. To accomplish this, bolts must be installed in two holes with varying weight and location guessing. I started with 3.3 IPS and stopped at .05
It appears the ideal process would be a link that spans two adjacent holes at the approximate location needed, and a way to secure varying weights at easily adjusted location on the link between holes. I envision this is the only way to get really close to perfect without a lot of luck and patience.
Before I ponder this objective any more, I thought the braintrust may already have the solution. Your input is appreciated.
