Would appreciate seeing some images of the RV-12iS mounting positions for the Dynavibe sensors. Most of the ones I'm finding are for the UL. Thanks.
I am pretty sure it is a M8. There are 2 common pitches 1.25 and 1.0, I don’t remember which it is. Most likely M8x1.0.Do you recall what bolt size fit that gearbox hole? I thought it was an M8 but it didn't thread
Sorry, I lost track of that detail. I took a brute-force approach to this and had a variety of thread sizes and lengths. I took the ones that worked and put them in a ziplock in the (borrowed) test kit.Do you recall what bolt size fit that gearbox hole? I thought it was an M8 but it didn't thread
I believe it would be more accurate if you reversed the way you attached the transducer so it would be more centered over the engine.
It doesn’t matter, it senses the movement along the vertical axis. Left, righr, or center it all moves the same amount.I believe it would be more accurate if you reversed the way you attached the transducer so it would be more centered over the engine.
