My DWG 12 (grid B6) identifies 10 holes to *not* rivet in the W-704 bottom inboard wing skin. Basically every other hole is reserved. The note on the drawing says they are to be dimpled later for 8R8 screws attaching the F-776 center bottom skin per DWG 38.
But, DWG 38 (grid E2/F2) shows only 8 holes for screws, and some of them are different holes than DWG 12 specifies! Instead of every other hole, it's every third hole (except the most aft one). [Note that on DWG 38, the "bottom" of the wing is shown on the top part of the illustration.]
The two drawings are dated within a month or so of each other, and the revision histories do not mention these grid areas.
Looking at my as-yet-untouched F-776 center bottom skin, it appears to not have holes pre-punched here, so my guess is it doesn't really matter whether I follow DWG 12 or DWG 38, but I thought I'd check the collective wisdom here.
So, are there any recommendations or gotchas I should be aware of before I proceed? I'd be inclined to go with the higher number of screws and follow DWG 12, but the top side has a screw in only every 3rd hole, and both DWG 12 and DWG 38 match (for the top side) with 7 holes being countersunk through the skins and wing-walk doubler.
