rjcthree
I'm drilling the rear spars. I came up against an obvious issue that may be simple interpretation.
The rear spar bars are 1 1/2". The instructions require a 5/8" edge distance. The hole to be drilled is 5/16" diameter. See the problem? THe math doesn't work. I took this to mean there must be 5/8" stock all around the hole post-drilling.
OR . . . do the instructions mean that the CENTER of the 5/16" hole must have a 5/8" edge distance?
The engineering handbooks interpret this both ways, and since the GD&T of the drawings is a little weak (non existant) I've got nothing but you guys to ask.
Right now I'm about 1/64" off of dead center (vertically) of the rail at 1/4" dia hole, so I can center if I must. Just looking for some clarification. I'm likely overthinking this one.
Rick 90432
PS: it's entirely possible to install the wings by yourself with a table, car roller skates and some patience. Takes about a half hour.![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Rick 90432
