I have wiring harness from stein with all the wires for the EGT/CHT probes (brown wire). My Garmin engine sensor kit has all the probes which are terminated with staggered ring terminals with small screws.
I need to make connections between the brown wires and these probes - what are the acceptable/common methods for doing this? I've been using butt splices sealed with shrink tube for connecting other miscellaneous wires (in some cases of course devices have their own terminal plugs i.e. PMAG).
Thanks in advance!
Thanks in advance!
