It turns out that if you push hard enough on the Philips screwdriver to keep it from slipping out of the screw on the back of a Potter & Brumfield breaker while it is mounted in the panel, that you can apply enough torque to break the front of the plastic case.
Note to self: support the bottom of the breaker case while tightening the screw. Fortunately, Stein has more.
